Apps Will I be able to use C++ libraries when developing for Android?
Yannbane
I'm currently making a purely math and algorithm-based C++ library. Will I be able to use it when developing for Android? How? I guess writing some Java wrappers, but will it then be usable on all JVMs?
If you make use of the Android NDK, or even create a wrapper Java library that uses JNI to reference your native library, then yes, but directly, no.
Yeah, I'm perfectly fine with using Java wrappers.
My library is contained in a .a file, including all the headers. I hope this will work without many changes...
