Help will it work....
jms209
so if i buy a Samsung galaxy S phone online and try to use as a regular mp3 player,would that work :p
does it having a good or bad ESN mater at all with this,what i mean is can i buy it and fully use it(without 3g) as a normal android mp3 player :cool:
Seems an expensive way to do it but I have a spare I9000 (long story) that powers up with no SIM card. Appears functional.
I think the answer would more be Dependant on the software you would use to play the files, the hardware would not be an issue, battery life may be :(
Its works just fine. Dont see the point with it.:confused:
Why not just buy an android MP3 player? If you don't want the phone part. Samsung has the Galaxy Player which is basically a galaxy phone with no phone part.
