Muslimahxo
will the Orange San Fransisco get android 2.2?
Probably not officially as it's a budget phone. But unofficially several devs on MoDaCo are frantically working on it. They have 2.2 working with one slight issue...
The phone part doesn't work![]()
hi - i personally was going to apply a custom rom to this phone, but just simply deleted the orange apps that were cluttering up the phone....PERMENANTLY...even now a factory reset does not bring the orange stuff back..unlock code for
just to mention if you follow the hot uk guide to roo as above remember to make sure when copying and pasting to the command screen that you may have to change r2 to r3
dyu kno with the SF can u play vidoes with Flash like youtube vids and stuff?
does the SF have a 3.5 mm audio jack?? ?
which processer does it use?
wud it be complicated for me to install the custom rom and all that?
thanx for all the info evri1, much appreciated =) ..just 2 more thingz tho..:
does the SF have a 3.5 mm audio jack?? and which processer does it use?
and im only tech-savvy to a certain point..so wud it b complicated for me to install the custom rom and all that????..it looks quite scary..:O
just moved onto the R5 rom which is the lighetest one with no crap at all with only the stock android apps and it is the best ,im going to be staying on this one for sure the phone is very quick now and also has the proper android boot up logo
