Help Will T-Mobile phone work on ATT LTE?
pypeke
I am looking for an unlocked Note 3. I see lots of T-Mobile phones. Will a T-Mobile Note 3 work on ATT's LTE with the same speed?
The ATT version is SM-N900A.
The T-Mobile's version is SM-N900T.
Factory unlocked version is no carrier? Will it work on ATT's LTE with same speed? I see SM-N9000 and 9005 and 9006.....
Will international version work on ATT's LTE?
My old phone is no longer taking incoming calls. I need to buy a new one quickly.
Thank you,
Patti
Thank you,
Patti
The N9005 doesn't support any common US lte frequencies and also has a region look on it so it won't work in the US at all.
A quick search of the 900T didn't not provide very detailed specs to show if it supports band 17 lte or not unfortunately.
