Help Will the Backflip get 3G if it is unlocked for T-Mobile?
Bbased off that the backflip works on a different 3g signal than T-mobile; more than likely the answer is no. I do know that when I had a G1 and used it on AT&T, I had no 3G, it said 3G in the notifaction bar, but it was not 3G.
So supporting one of T-Mobile's 3G frequencies won't mean that I'll get 3G?
From my understanding Tmobile 3g uses two different frequencies. One for Uploading and one for Downloading. The backflip needs to have both frequencies in order to get 3g to work correctly.
I'm taking a wild guess here but i think the frequencies are 2100 MHz for Downloading and 1700 MHz for Uploading. So the answer would be NO. The phone WILL work on Edge though. and all other operations won't be affected.
So I'll get 3G speeds down and EDGE speeds up?
