Will the note 3 Screen Protector work on a note 4
Captain Sexy
I would assume yes, but wanted to make sure i'm not missing something. The sp I want for now is only available for the note 3 so if it will fit i'll just order that.
One would assume that it would since the screen size is the same....but you never know:)
I have an N3 screen protector on my N4. Be careful around the home button: that's ever so slightly different; If you are spot-on with applying the thing, you're golden. If not, it'll bubble up just a bit (also does this around the edges)
