Root Will Xposed work on this?
Cydia is an alternative to the app store. Xposed is a way to alter apps without rewriting them or flashing new ROMS. Two totally different things.
In Android, you can find apps on a few safe alternate sites, like Amazon App Store. (There's an app there that will let you install apps from Amazon. https://www.amazon.com/gp/feature.html?ie=UTF8&docId=1000626391&ref_=mas_dl_appstore_rr ) There's also a Free App of the Day app on Amazon. I've gotten some pretty good paid apps for free (legally) using it.
Thanks, but I didn't literally mean exactly like Cydia, only the fact that Cydia has loads of things. I do still want to know if Xposed works though 😕
Thanks! I currently just added "OK, google" to work on the home screen! So awesome to get that Nexus 5 experience
Somewhere on your SD card has the info stored but you need to be rooted, and also flash the model and reboot when them red lines turn green you are good to install any mod .
I haven't seen any but u can get the download and keep the zip file to disable if a problem starts . you can do that instead of reflashing a ROM or the last resort of wiping everything and start from scratch
I haven't seen any but u can get the download and keep handy . once you complete the work just reinstall . its a pain I had to use vbox to root a device but when I had it running it disabled other devices til it did its thing . what you using the box for
I'm totally new to using Xposed, it's the first time ive heard about it. I'm not sure I should use it yet xDD
Can xposed block Pandora's ads? It sounds a lot like lucky patcher, in that it patches apps, rather than acting as a firewalling type of ad-blocker. Lucky patcher I'd really neat, for example it can patch the app store to allow 240dpi apps etc. Its strange how quick office isn't in the appstore, I'll probably need to install lucky patcher to see. In the meantime I am sideloading missing apps from my lg motion.
Does rom toolbox work on this phone?
Nothing wrong with it u can tell my time is center and my battery is circle with percent in the middle
