Winamp - Disc Washer
mbrogden
Hi guys, this is my first post on this forum
I have a rather annoying issue with Winamp Discwasher for my music. When i have "washed" a album to get the artwork it put the image in my Gallery, now you can imagine over time that this has become cluttered with different album artwork. Is there a way i can stop them appearing in my gallery without deleting them?
Thanks
If it puts them all in one folder where no 'normal' photos reside, you could place a .nomedia file in that folder. This should prevent Gallery from using that folder.
You can create a .nomedia file with most file explorers (I use Solid Explorer).
Make sure to include the dot and don't give it an extension.
Alternatively you could create a .nomedia file on your Windows pc:
Open a dos shell: click start, run, then CMD and press enter. Then enter the following:
echo > c:\.nomedia
Now close dos shell with Exit.
The .nomedia file is now in the root of your C: drive. Now copy the file to the folder you want Gallery to ignore.
