Apps Windows 7 64bit Android SDK Platform tools rev 9 not able to installed Null Done nothing was install
Setting up Android SDK
Installed Android SDK for windows in the location C:\AndroidProject\androidsdk and run "SDKManager.exe" as an "Administrator"
then
Android SDK Manager list out
Android SDK tools Rev 20 - Installed
1) Android SDK Platform tools Rev9 using Android -Not Installed
2) API 10 Rev 1 Dual Screen APIS - Not Installed
3) API 8 RevDual Screen APIS - Not Installed
Click Install 3 packages and it prompts with Accept , Accept All and Reject Radio Button on right hand side with displaying above three options on left hand side
If i select "Accept all" install button is fade out, because API 10 and API 8 has some dependency
if i select API 10 rev 1, it displays This package depends on 'Missing SDK Platform Android,API 10
if i select API 8 rev 1, it displays This package depends on 'Missing SDK Platform Android,API 8
So I have select Option 1 alone Android SDK Platform tools Rev9 using Android and accept it, it enabled install button and i click installed. After progress SDK Manage logs message "Done. Nothing was installed". Please see the logs below and try to help me to set Android on Windows 7 64bit
Logs Messages
Fetching https://dl-ssl.google.com/android/repository/addons_list-2.xml
Fetched Add-ons List successfully
Fetching URL: https://dl-ssl.google.com/android/repository/repository-7.xml
Validate XML: https://dl-ssl.google.com/android/repository/repository.xml
Parse XML: https://dl-ssl.google.com/android/repository/repository.xml
Found Android SDK Platform-tools, revision 9
Found Android SDK Tools, revision 15
Done loading packages.
Validate XML
Parse XML
Fetching URL: https://dl-ssl.google.com/android/repository/addon.xml
Fetching URL: http://dl.htcdev.com/sdk/addon.xml
Fetching URL: http://software.intel.com/sites/landingpage/android/addon.xml
Fetching URL: http://www.echobykyocera.com/download/echo_repository.xml
Validate XML: http://www.echobykyocera.com/download/echo_repository.xml
Parse XML: http://www.echobykyocera.com/download/echo_repository.xml
Found Dual Screen APIs, Android API 8, revision 1
Found Dual Screen APIs, Android API 10, revision 1
Fetching URL: http://developer.lgmobile.com/sdk/android/repository.xml
Fetching URL: http://android-sdk-addons.motodevupdate.com/addons.xml
Fetching URL: http://innovator.samsungmobile.com/android/repository/repository.xml
Fetching URL: http://developer.sonymobile.com/edk/android/repository.xml
Fetching URL: https://dl-ssl.google.com/android/repository/sys-img.xml
Validate XML: https://dl-ssl.google.com/android/repository/sys-img.xml
Parse XML: https://dl-ssl.google.com/android/repository/sys-img.xml
Found Intel x86 Atom System Image, Android API 15, revision 1
Preparing to install archives
Downloading Android SDK Platform-tools, revision 9
null
Done. Nothing was installed.
Validate XML: http://software.intel.com/sites/landingpage/android/addon.xml
Parse XML: http://software.intel.com/sites/landingpage/android/addon.xml
Found Intel Atom x86 System Image, Android API 10, revision 1
Found Intel Hardware Accelerated Execution Manager, revision 2
Validate XML: http://developer.lgmobile.com/sdk/android/repository.xml
Parse XML: http://developer.lgmobile.com/sdk/android/repository.xml
Found Real3D, Android API 10, revision 2
Found Real3D, Android API 8, revision 1
null
null
Mjm... You can always check: Windows Firewall,
Your antivirus,
Restarting,
Reinstall,
Internet Connection,
Close/Open,
Install Dependency first,
Setting SDK manager.exe to run as administrator first,
Download 1 item at a time,
If there's any corrupt file.
Good Luck!
