Root [WIP][RECOVERY][CWM]ClockworkMod Recovery 5.8.2.4 for EVO 4G LTE
Granite1
Zercron Encrusted Tweezer
First off this is not mine!! :)
Please see this thread for the OP:
[RECOVERY][CWM]ClockworkMod Recovery 5.8.2.4 for EVO 4G LTE - xda-developers
This recovery is a work in progress, it was released, then pulled. I'm just providing a link and the recovery info for folks to follow as development happens!! ;)
OP by -viperboy-:
Woohoo! ClockworkMod Recovery brought over by the one and only toastcfh!! Recovery is the basis for all of the work we devs do here, so please thank toastcfh for this as it was all his doing! The man doesn't even have this phone and he did it, please donate to him so we can get him an EVO 4G LTE!!
What works
  • Backup
  • Restore
  • Flashing. zips
What doesn't work
  • Mass Storage
  • Touch
Requirements
  • HTCdev Unlock (Choose "All Other Supported Models" and follow all the directions, including driver install)
  • Rooted
How to flash via phone (Recommended)
  • Download the ClockworkMod recovery.img below and place on the root of the internal sdcard. Make sure to rename to recovery.img if necessary!
  • Download Terminal Emulator from the Market
  • Go into Terminal emulator and type "su" (lowercase, no quotes) and accept the Superuser prompt
  • Then type this exactly (no quotes) "dd if=/sdcard/recovery.img of=/dev/block/mmcblk0p22"
  • If should tell you records in and out and then recovery is flashed!
  • To get into recovery, you can type (no quotes) "reboot recovery". You can also access it by pressing Volume Down + Power while booting up, and then choose "Recovery". NOTE: You may need to disable Settings > Power > Fast Boot for this method to work.
How to flash via fastboot
  • I will update instructions later, but if you choose this way, you likely know what you're doing. Make sure to rename to recovery.img if necessary! Place the ClockworkMod recovery.img in the platform-tools (or even tools folder, depending on your SDK version), reboot into fastboot, and type:
Code:
fastboot flash recovery recovery.img
How to flash stock recovery
  • Follow the same set of instructions you used above, just download the stock recovery.img below.
  • Make sure to rename to recovery.img if necessary!
Credits
  • toastcfh for bringing over CWM without even having the phone!
  • -viperboy- for testing!
  • xHaus, Deck, and everyone else in IRC who tested!
Downloads
ClockworkMod version pulled for now. This is causing an empty /misc partition, a fix is in the works!
Stock recovery.img
Once the recovery is approved by the devs to be working, I'll update the thread.​
