Wipe HP Touchpad & Start Over - FEELING LOST
Branchard
Hi - I am feeling so lost about my problem. I have an HP touchpad that I installed Cyanogenmod on and I wiped webOS from it too. It was working okay and then suddenly it's just not working correctly. It keeps crashing a lot and a LOT of applications crash and it just seems impossible to get it to work correctly. I've even deleted apps off of it and they reappear after rebooting.
I really want to wipe the entire touchpad clean and just start over. But I'm not having luck on getting this done. Can anyone help me achieve this? I'm pretty smart when it comes to technology but this task is driving me nuts and I just can't seem to get anywhere with it.
I tried ACMEUninstaller but it doesn't seem to do anything for me and everything is still there.
PLEASE HELP!!!!!
Since you used TouchPad Toolbox "Complete Data Reset" the first time, do that again and try reinstalling Android. You can also use TP Toolbox to set up your TouchPad to reinstall WebOS if need be. Just follow Sullin's instruction to install WebOS.
Haven't been here in a while, so sorry about the late reply.
NT
I'm new to this forums don't know if I'm butting into to a conversation, but my touchpad will not close the screen is on but will not unlock. I think it has evovlv on, just ourchased it.
David
Take it back to the person you purchased it from and tell them to fix it.
