As my frustration with my Strat was growing ... hanging at random times, restarting randomly, freezing intermittently ... figured it only made sense to attempt a factory reset before declaring it a failed device.
I had gone so far as to purchase an extended battery because I was only getting a few hours with the original, but before the reset I carefully timed the extended battery as lasting only 6.5 hours with barely moderate use.
Oh, what a difference a wipe makes!
OK, a post-wipe lesson was that I really didn't need all of the apps I had loaded. But, again, I wasn't crazy nuts about apps (still had 20% core memory, 60% on the SD).
But given how zippity fast its running -- with now 12 hours on the extended battery -- it leads to me ask, should a factory reset be a part of regular maintenance, every 3, 6, 9 months?
Actually, I just checked and my Strat is a year old.
But the question still stands.
Is it reasonable to expect a device in moderate use to not need a reset?
I'm guessing that somewhere in the past year I installed/uninstalled something that left a monkey in the wrench of the system.
UPDATE T-Plus 1 day - Extended battery after 16 hours, still registering 56% power left
