Help Wired Headset Controls Not Functioning
IHateMyTreo
Android Expert
So you know the wired headsets with built-in mics have a way to skip music tracks, go back, pause, etc. by clicking the mic button once, twice, etc.? I have tried two different headsets with my MAXX HD, and other than a simple pause function, the clicking function doesn't work on either for music control on the Klipsch S4A or the Audio Technica ANC9. No matter how many times you click, it is interpreted as a single click. Phone pick-up and hang-up works on AT. So I'm wondering if this a RAZR/Moto issue since two different high-end headsets seem to have the same problem.
SOLVED:
Well, this is hard to believe.
When I purchased the Klipsch headset yesterday, the manual said that in order to have functionality, I had to download the Klipsch control app in the Play Store. So I did.
I just uninstalled the Klipsch app. Problems gone. Controller works as intended. What the heck?
Side note: Yesterday, I called and emailed Klipsch tech support for help, and gave up after 30 minutes on hold and never got an email back. Maybe Klipsch should stick to just making things other than headsets.
I've had the same problem with skullcandy headphones. I've tried different "button" apps, but can't get anything working.
