Wireless charger pad that doesnt beep
I have the Samsung charging pad. The pad itself doesn't beep, but the S4 does when you place it on the pad. When charging is complete, the screen says as much but the phone doesn't beep.
The energizer one doesn't beep, and I opened up the PowerQi one and clipped the speaker wire, so it no longer beeps either =P
Nexus Orb doesn't beep, the phone makes the same tone it always does when it's put on a charger.
do you need to replace the back cover to use wireless charging pad?
Not necessarily.
Some wireless charging coils are very thin at about 0.6mm and can be used with the existing back. There is/are thread(s) about this here somewhere if you have a poke about.
