drkrishall
Is there any way to mute or change the wireless charging sound? For some reason mine makes the sound twice within the first 30 sec of setting it down. Thanks in advance!
I agree. I hate the sound, and if I put the phone on the charging station when my partner is asleep, a big noise happens. Even if I have the volume off, it seems -- though again, I have no idea which of the several volume controls affects this annoying sound.
But most importantly: how is that sound controlled? All other notifications have settings (including selecting a sound and silencing entirely) except for this one. Very annoying.
If the sound file is in the app and not a system sound, it may be possible to fix without root.It's in the app, and there is no setting to silenced it at this time. Perhaps that will change with the KitKat update?
If it were me, I'd just plug in overnight rather than using a wireless charger if you are concerned about the noise.
I don;t have the charger so i can't test it.
Does it happen if in Silent Mode? Hit the power button and select the bottom-left icon.
If that stops it then you can manually set it or perhaps have Tasker set it.
... Thom
Sorry ... I did not follow that ... if you put it in Silent Mode using the Power and menu method and then place it on the charger do you get the offensive sound?
... Thom
I'm trying to remove as many variables as possible ... if right now you manually hit the power button and selct the silent icon (botm left) and place it on the charger you get the sound?
... Thom
My thought process was, if the sound file is in the app and not in the system, theoretically the sound file could be replaced with a silent sound file and the "fixed" app could be manually loaded.It's pretty well reported that wireless charging cannot be silenced without root since the 12.15.15 ota...
Lots of reports that it doesn't work. I don't see where anyone tried the 5 second test that I was hoping someone with a charger will try. Hit a button, select a menu item, put it in the charger , and then tell me it doesn't help.
I understand that it might not work. What I saw this weekend was false reporting of of other information in system settings and correct reporting of Silent Mode.
This is only a test.
... Thom
