Help Wireless comes on every time I plug in my phone
Tony407
My phone just updated yesterday (Ice Cream Sandwich maybe?) and now every time I plug in my phone for charging the wireless turns on. I searched through settings and can't find anything that might be causing it. Any help would be appreciated.
Tony
Ice Cream Sandwich? No. Definitely isn't. Definitely won't ever be.
I'm not sure what your issue is as your not being very clear. By wireless do you mean wifi is turning on when you plug it in?
It could be the new connections optimizer included with the new FC09 build. Either go to settings/wireless and disabled it or change it's settings.
That's the only thing I could figure might cause that "if" that's what you meant.
Yes, Wi-Fi. I don't see anything in settings, under 'wireless and network' or any others for that matter.
Is the optimizer something I can go into aand make changes to? I'm not even sure what it is, much less where to find its settings.
Tony
I haven't used the build with it included. I've been on 4.0 for months.
It's around in there somewhere assuming the update you got was to build id FC09.
Yea that's the thing I was talking about. Just haven't been on a TW based rom in forever let alone the most current build.
