Help Wireless N not working?
nickmv
I've been running a Linksys Dual-Band N/G router for a while, and am submitting this post on my Macbook Pro using the N band. However, my Nexus S doesn't see it at all. I have no other N network to test with, so I can't really do any troubleshooting. I have tried adding it manually, but it doesn't see the network. Is anyone else having this problem with WiFi-N networks?
Nevermind, I figured it out. Turns out that my Linksys WRT610N broadcasts an N signal on both 5ghz and 2.4ghz frequencies. I did not know that the 2.4 broadcasted N, and had labeled my SSID's as "airN" and "airG". Turns out the airG was broadcasting B,G,and N on it @ 2.4ghz, and I was connected at 65mbps, so it clearly works.
