Root wireless teather for root users
casper604
I've been trying to teather with my cm eco v. I can get it turned on but it says failed to activate WiFi. Not sure if it makes a difference but I'm using the stock room from the newbie guide to rooting . Does that rom support teathering?
I am rooted and all. Barnacle does not work for some reason says I don't have root access which is funny cuz I've already gave it su privileges. I have not find a single free teather that works. Wireless for root is just the one that comes closest.
Also check to make sure of the settings. I'm on Harmonia and it works for me. Make sure the device profile is set as Generic ICS/JB (wlan0) and make sure the routing fix box is checked. If there is still a problem, try checking the WiFi-driver reload box. Works flawlessly for me
It could be something with the stock ROM, I don't have much experience with it myself so maybe you should try a different ROM. Plus it will boost the performance.
Yup assuming your S-ON I would recommend Mobster Remix. Its really nice and runs smoothly. There's a list of instructions on how to flash in the OP.
However if you want to keep a somewhat stock ROM, or just want to keep sense Harmonia is always a good choice.
And if you do happen to be S-OFF Angry bean is great.
i flashed mobster remix. and although i like the way its set up i lost my 4 g compatablility. flash back to stock rom for now till i find something better that works for wireless teather.
As has been posted numerous times, you're not shorting anything, what the wire trick does is it takes a pull down resistor low allowing the phone to enter an engineering state. It took some smart people to figure out this undocumented way to get write access to the emmc, but that hole isn't there just by accident. :D:rolleyes:
OB
Apparently I just didn't read into it enough. Thanks for the info. I got the teather to work but my comp can't actually do anything once connected.
got it to work now just need to try it on my xbox. that is my main goal. i want to usb tether to my x box so i can get on x box live.
