Help Wireless update
  • Thread starter Thread starter Itel it1702
  • Start date Start date
I
Itel it1702
Guest
Since I updated the wireless update of the android,all my apps have stopped working
If you're talking about ,(OTA) over the air updates from your mobile service provider. Sometimes it's best to do a factory reset of the device after the update is installed so the update will property install into the device.
