Help Wireless
hello I 've just on getting lgg stylo and I noticed today that my cell takes all the wireless
even if my cell phone is in standby mode and all my close its implementation !! I tested by switching off the device and the actual duration ca takes on all the network home ,computer and smart TV are slow and are very bad I do not know if this is happen to one of you but among j ' wish I could use it at home !!! someone would have a solution?
even if my cell phone is in standby mode and all my close its implementation !! I tested by switching off the device and the actual duration ca takes on all the network home computer and smart TV are slow and are very bad I do not know if this is happen to one of you but among j ' wish I could use it at home !!! someone would have a solution? end sorry for my english i speak french !!!
I use my phone on my home wifi and have not noticed it to use a lot of bandwidth. If you just activated a new phone, it may be downloading a lot of updates - maybe even Android version 5.1.1 (mine did). After all the updates, things should return to normal. Maybe that is what you are seeing.
how long it takes it's been three days since I buy and this is always the same problem ??
Depends on your network speed. The Android 5.1.1 update is several hundred megabytes I believe. I would think 3 days would be plenty of time. You probably need to take your phone in to have it looked at.
