bern_viking
Hello
This is a smaller bother, but it is there:
I can connect to the internet over mobile internet (3G) or WLAN at home/office. This works well almost all the time, with one exception:
When the WLAN is on but not connected to the internet (the DSL modem is off but the home net is up), android will drop the 3G connection, log into the WLAN but you can't access the web (obviously). I then have to switch off the WLAN access on the phone.
Yes, there are bigger problems out there, but I was wondering if there is a way to get android to check if there is a working internet connection on the WLAN and only log in when that is so.
And yes, I could get up from the sofa/bed and switch that modem on, I know...
Thanks
S.
Thanks
S.
