Help WM8850-mid (Eken W70 clone) auto "waking up from sleep"
Hi guys!
I recently bought 7" WM8850-mid tablet, I got no problem with this tablet aside from putting the tab on sleep mode.
after pressing the sleep/power button the tab goes into sleep but in a few seconds, it turns on automatically.
I got this unit brandnew and it has this issue before I install some apps.
I want to know the culprit that cause this issue but BetterBatteryStats app is not compatible with this device.
the temporary solution I got is the CPUwake app, but it can only turn the screen off and the system is still on wake mode and running @ 1.2ghz which drains the battery fast.
unit specs:
WM8850 1.2ghz / 512ram / 8gb storage / Kernel 3.0.8 / ICS 4.0.3
