WOL not working
EfcLee1
Hi
I have Wake on Lan installed on my Galaxy Note but it does not turn on my PC's
I downloaded the one that has image of brick wall inside a white cloud
SO I proceeded to add my PC mac address and name then clicked SAVE, clicked on SEND PACKETS, nothing????
Then I entered the IP address which is DHCP from my router and I know this changes a lot becuase I have shares added to ES File Explorer and had to change the IP's
So after entering IP it says PACKET SENT SUCCESSFULLY but PC remains OFF
SO then I go into the BIOS of my P5Q Deluxe and change the WOL settings
Onboard Devices Configuration is the only place were I find any setting
Marvell LAN1 Enabled
LAN Boot ROM Enabled
Marvell LAN2 Enabled
Wake up by PCI Devices Enabled
Wake up by PCIE Devices Enabled
On my PC I right click the device in Device Manager and....Property: Wake-Up Capabilities has Value: Magic Packet & Pattern
Also is selected under Power Management
"Allow this device to wake up the computer"
and "Only allow a magic packet to wake the computer"
I have a Virgin Super hub as my Wireless Device which my phone is connected to and then several Netgear FS108 switches
Any help would be great obviously there is something I have missed?
Thanks
Lee
