Root Wonder Media WM8650 ROM installing
i have 7 inch MID tablet and here's the info i have..
Model number
WonderMedia WM8650
Android version
2.2
Kernel version
2.6.32.9-default
Build number
generic-eng2.2 Froyo Ver1.5.5-20110920.083830
can i do this tutorial?
link: http://www.a n d r o i d t a b l e t s.net/forum/wondermedia-wm8505-tablets/14822-rom-universal-hybrid-honeycombmod-uberoid-wm8650-devices-v1-3-0-a.html
instructions: remove the spacse on the word a n d r o i d t a b l e t s
or how about this one...
http://www.techknow.t0xic.nl/forum/index.php?topic=846.0
or can you just help me install HYBRID Uberoid? by making a thred or instructions here, pls help me.
Hi tumaeka123...
I have the same tablet, did u have success with the upgrading through those links u shared? I need to find the suitable rom to upgrade the version 2.2. Could u give some advise?
wm8650 Specifications
Processor
WM8650
Main frequency
800MHZ
Games suit version
Built-in 146 European and US hot console games, support games download(Wireles remote control in 10 meters range)
Display screen
7 inches TFT capacitive touch screen, 16:9
Resolution
800*480
Memory
DDRⅡ 256M
Flash memory
Standard configuration 2GB
System
Android 2.2, 10.1 flash
Loudspeaker
Built-in 8Ω/1W loudspeaker x 2
Reset hole
Hidden(restart function)
Top key
Switch-on key + menu key
Front main key
Right/backward key
Camera
Built-in 0.3 MP camera
Support external 3G
WCDMA(HUAWEIE220/E230/E169G/E160X/E1750) CMDA2000(Bora9380/AWIT-U8) TD-CDMA(TD368)
WIFI
Support IEEE 802.11b/g, Ethernet 10/100M
Audio equipment
3.5mm standard earphone port
USB port
30/24 pin port output, can be expanded to USB2.0 x 2, RJ45 network port x1
DC-IN port
DC charge port 9V 1.5A
Card socket
Standard TF card slot, the maximum is up to 32GB
Microphone
Built-in
Battery
Polymer lithium battery 1800mAh/7.4V
Adapter DC 9V 1.5A
I have one of these tried uberoid v10 and v12 but could not get any rom to work some loaded so far then stopped at copying file to drive, I got some to boot but the touch screen would not work and they was wrong resolution. stupid me has no rom to restore the original... Anyone got a rom to work on these machines yet?
UPDATE: Well zippperdy doo daa day I finally got Uberoid to install using Version 12.1, rom 136 ..
I feel so bloomin happy! Bang on Guys ! I was worried my tablet would be bricked for ever...
