Help Won't boot after reset
VooDooCC
Went to recovery, tried wiping cache, after about an hour I thought it was just frozen and not doing anything, so I restarted the phone, then went back into recovery and factory reset. Now the M logo appears for a few seconds, then disappears, but the screen buttons are unresponsive. At this point, the only thing I can do is hold the power button and the M screen will come back up, OR I can get into fastboot and everything acts normal until I try rebooting. I've wiped cache and factory reset several more times and the same problem keeps persisting.
Any tips?
Thanx
Any tips?
Thanx
Use the Verizon repair tool.
