Are you trying to charge via AC or your PC? Hello and welcome to Android Forums. If you are connected to your PC make certain that the device is set to charge and not a storage device. You might make certain that your connections are good. It could be a hardware problem. I once received a refurbished Droid Incredible that would not charge. I hope you can find the root of our problem and the remedy.
Thanks for stopping by. It would be hard to pin point the problem - since you don't give us much to go with. Anyway, check the charger to see if It's working. Remove and reinsert the batt then connect the charger. If none of these things work - try using a different battery.
If all the above fails.... Replace the phone. Best of luck.
