wont charge
  • Start date Start date
A
Android Question
Guest
my Samsung galaxy ace wont charge . I know its not the charger as I have two and they both charge three other phones in our house
Sounds like either a problem with the battery or the USB slot on your phone.
If you connect the charger, does the phone say it's charging or does it not respond at all?
If it says it's charging, it might suggest the issue is the battery (try a new one) otherwise it's probably the USB port (you'll need to send the phone for repair, I'm afraid)
