Help Wont come on
try holding power button for 30 seconds. it might be in a "deep sleep" if you were charging it or something
sounds like a good old fashion android lockup.
Make sure you have the latest version of android.
think about the last app you installed.
Will your computer see it if you plug it in?
Can you boot into Fastboot (hold volume up & Down along with the power button)? Might need to do a factory reset if you can.
My computer did see it but that's about it. I don't know how to do anything after that. I did try holding the volume/power button but still nothing. It's now on it's way back to Amazon and I have another coming to the Wal-Mart near me. The one from Wal-Mart is $70 cheaper and is 32gb as well. I hope this is the last issue I have with a tablet. I'm beginning to think I'm cursed :rolleyes:
