Help Won't even pick up data
Works on wifi. Turn off wifi and won't pick up data. Shows full signal with no 3g and or 1x. Did simulated battery pull still no help. Any ideas?
Did you by any chance have a smart action on that turned off cell data? Sometimes they don't reset things when they shut down. I'd set up a SA that specifically enables cell data and see what happens.
This plus check ifAPNs are still there.
I'm currently in Omaha and I have spotty 3g and mostly no 3g on my incredible. Verizon having issues with coverage?
If you have no data at all:
settings> wireless> mobile networks> network mode> change to CDMA Only> home button, then airplane mode (hold down power button and select), then un-airplane mode. You should then have 3g data until things are fixed (I hope this isn't just a transient fix). You need to turn off WiFi to see the 3G icon.
