Help Won't go into mirror mode?
So, why won't my Bionic go into mirror mode? I have the hdmi cable plugged in, the cradle plugged in, and it doesn't prompt me to do anything and my TV screen stays blank. I hope I didn't freeze something I wasn't supposed to... :/
I've got the same problem. Brand new Bionic. Just bought the cable and plugged it in. No prompt on the phone and all I get on the TV is a floating Motorola "M"
Had the same problem the other night. I was trying to watch Netflix through the phone and when I put it into the dock the menu came up but didn't give me the option for Mirror Mode or Webtop. If the menu is not giving you the option, believe it or not, I just wiggled the phone around a little bit in the dock and it popped up. If that doesn't work try rebooting. Good luck.
I've had issues with a cheap cable I bought off amazon, but it works fine with my buddies OEM Motorola cable.
