wont load
  • Start date Start date
A
Android Question
Guest
hey I have a versus touchpad 9 and I just bought a new screen replacement and it turns on and the android robot comes up then it shows the vs logo and I stays on that for ages and wont load fully it wont go past the logo ........... any answers to fix it
First find out what you broke when you replaced the screen. (I know, you didn't break anything. You did, If you didn't, and you installed the new screen properly, the pad would be working.)
Then fix tat.
