Root Won't recognize headphones
shyFluttershy
Not sure what else to say but "argh." Prior to my recent reset, it wasn't an issue. Plug in headphones, boom, the phone asks me what I want to listen to. Now, though, I plug in headphones and nothing. I adjust the volume and I hear it out the speakers, no matter how much I fiddle with the jack.
I probably need to do a proper Kies reset like I'd set out to do originally. I have no idea what went wrong.
Meh. :banghead:
Just curious, what music app are you using? Currently I'm using the stock app and mine doesn't even ask me what I want to do, it just plays through the headphones when I plug them in. But I remember it asking me at some point in the past. Which I know doesn't solve your problem, just wondering if there's a setting somewhere that we're overlooking.
Can also try looking down in the jack with a flashlight, there are two little tiny brass pins, you can very carefully pry them out a bit with a sewing needle, but that would only work if it was a connection issue and not a software thing.
Previously, it was the system that asked me what app I wanted to launch when I plugged in the headphones. No big pop-up or anything, just a thing in my notification drawer. Last night, though, as I said, nothing happened and the sound went through the phone as though there were no headphones. I hadn't even launched an app yet, that was just me testing the volume with the side rocker.
I'll check to see if there's something physical to blame -- thanks for that suggestion.
Thanks.
only a custom kernel couldve borked voltages like that, otherwise its a hardware problem and has to be taken up with warranty
What's the fix for that?
Thanks.
Before this is asked in the MiRaGe thread, headphones are working with MiRaGe kernel :)
I know whatever problem you have I always say it is not related to kernel so far. But it is just the case so far. I hope I can fix one of your problems in the kernel in future, not that I am wishing ill to you but anyway :D
Just out of curiosity, what was it?
You mean besides extraordinarily embarrassing? :o
It was a stupid and unfounded assumption that I failed to explore before jumping to conclusions. Just because the volume adjustment comes out of the speakers (particularly while no particular sound-producing app is running) while the headphones are plugged in does not mean that the sound will fail to go through the headphones once a sound-producing app is producing sound. It also may or may not have had anything to do with my Page Buddy settings.
Let this be a lesson on how not to derp!
To quote James Woods as Hades in the Disney classic 'Hercules'... "Two thumbs, WAY, WAY UP!":D
my phone couldn't detect my earphone, i tried to clean the headphone and tried other earphone but still not working, I also tried downloading SoundAbout application and it work but do i need to use third party applications just to head sound on my earphone..can u help me
