Help WONT STOP CHARGING HELP
syfer1987
Hi my Samsung tab 2.7.0 is doing something strange. The charging icon use to to be red but then I rooted this which I did and I have running Resurrection Remix 5.0.2 Lollipop v5.3.7 2nd Mar 2015. Even before rooting it the battery would have red x on it and it would be stuck on charging made even when the cable not switched on if you click the power it would say charging even with the wire not plunged in. I did replace the battery also. Can some help me fix my problem.
Thanks.
