Help wont turn on past samsung screen continues to vibrate
samsung admire wont go past the samsung screen it continues to vibrate, i was tryin to install a new font via root tools which has worked on all prior phones, i tried to hard reset still wont work
for future refs, dont try any morph themes or fonts with a rom recovery/backup...but since it wont go past anything i suggest taking it back to store and tell them when your battery died and you plug it in to charge and tried powering it on, it never past the samsung screen.
Ok.. a dude found a way to fix this. i had the same problem it doesnt go past the samsung screen and constantly vibrates. well all you half to do is turn off phone hold volume down power button and back button all at the same time then it sould bring up a menu (use volume buttons to scroll up or down and home button for enter)hit recover phone and thats it.it should take awhile. if so this doesnt work you might half to erase all your data and repeat the same process just as i did. :)
The original posters problem actually just happened to me last night. Factory reset didn't work here, nor did it on the previous android admire phone i had (look at my post, problem occured a week ago). custom font and delete cache on boot up, that's what i changed. any idea of how to do a different reset? maybe reinstall somehow?
That only works for a minute it never last
