Help Wont turn on unless connected to charger
kayos777
Hello community,
my samsung vibrant has been by reliable companion for about 2 years now and i have rooted it a long time ago. I recently started coming up with a problem where:
The phone is showing a loading icon a smal white frayed circle in the middle when its turned off.
The phone wont turn on unless i connect it to the charger that is connected to the wall and press the up volume button and the power on button.
When its connected to the computer it goes straight to download mode with yellow android icon appearing with the shovel
When its not connected to any power source and is turned off the phone continuously flashes the loading icon that i mentioned above.
any ideas on whats up?
Also i think this problem might have occured when i tried to clean files from the main sd card that were useless or i thought were useless as apps can leave behind many folders once uninstalled.
ok so odin it to stock and put it back to 4.2.1 still same problem. Somone told me it might be a problem with volum rocker and power button what do you think?
