What device do you own?
Post a model number, what version of Android etc.
It used to be that you could boot into the warning screen prior to download mode and choose cancel/reboot and it would boot past that message.Samsung Galaxy S5 SM900H, Android version is Marshmallow
i root it follow the instructions, this is the steps :"Odin", I presume it's a Samsung of some sort. But we need to know exactly what you've got there. How exactly did you try to root it?
If you go to the official cf autoroot site, your device is not listed....i root it follow the instructions, this is the steps :
- Download and unzip the CF-Auto-Root-....zip file (see posts below this one)
- If you end up with a recovery.img and cache.img file, you've extracted twice. You need to end up with a .tar.md5 file - don't extract that one
- (USB) Disconnect your phone from your computer
- Start Odin3-vX.X.exe
- Click the PDA button, and select CF-Auto-Root-....tar.md5
- Put your phone in download mode (turn off phone, then hold VolDown+Home+Power to boot - if it asks you to press a button to continue, press the listed button, or run adb reboot download command)
- (USB) Connect the phone to your computer
- Make sure Repartition is NOT checked
- Click the Start button
- Wait for Android to boot
- Done
when i buy it the android version is lollipop, then it automatically update to marshmallowIf you go to the official cf autoroot site, your device is not listed....
That's not unusual. What i meant was on the official cf autoroot site your device is not supported.when i buy it the android version is lollipop, then it automatically update to marshmallow
