R Deep Singh
Hi guys, just 2 quick questions.
1) I use Kingston Office for taking down notes in meetings and doing some word processing on. Are there any other apps that you would recommend?
2) Is there anyway I can create a folder either on homescreen or in the main menu for work stuff? e.g a folder called "Work" and once I open it, it has all of my office documents inside.
Thanks.
Thanks.
