Work in 2 apps side-by-side on Transformer screen?
teknofil
Hi! I would really like to buy a Transformer, but I really need it to be able to do the following:
Have a small internet browser open on the screen beside a text editing app/widget.
Is it possible on the Transformer? Given the large screen, I would hope that I could look at a wikipedia article on the left side of the screen and summarize things on the right side in a note-taking app for schoolwork. But are there widgets or apps that allow this type of multi-tasking?
Thanks!
-Kelly
Haven't seen anything like this yet. :-(
Hi! I got a reply in another forum.
There are 2 options that might work, but arent yet full options for us transformer owners... but they are in the works:
1. Onskreen Cornerstone. It allows you to resize your running apps into little windows! genius! beta testing went well, hopefully coming to devices if google will ever allow it!
2. TouchWiz, available on Samsung Tab. I tested it out at the store yesterday. at the bottom of the screen there are 5 widgets that will pop up and run over ANY app. they can be re-positioned and everything! people have put these on the transformer, but you lose wifi... so they are still working on kinks
When is wifi on, you can use Dual Screen browser - in one window open wiki, in second open gdocs. But google products working on android browser really poor. :mad:
Do you mean that it IS currently possible to see 2 browser windows on screen at the same on honeycomb 3.2 on transformer? Could you maybe take a screenprint of this to show us what it looks like? I would love to be able to have google docs open on one side of screen beside Wikipedia! :)
ss-1280-1-3
Basic Web browser features are supported. - Homepage, Bookmark. - Back, Forward and Reload. - Search (Google, Bing and Twitter). - (Experimental) Play HTML5/FLASH videos.
Special features supported in this version. - Resize screen. - Rotate screen. - Change UI Theme.
https://market.android.com/details?id=jp.mmasashi.android.dualscreenbrowser&feature=search_result
