I'm having trouble with multi-threading here. I have a thread that run multiple times, so I know this is multi-threading. The program reads data from a file and stores them into an array. The method postData() post a set of array data to my website, and then it deletes the array so that the program can read another set of new data. The Send.send_data(); method send data to my website, and that works, so I don't think there is a problem there.
It seems like I'm not receiving the data in order on my website and I'm also getting repeated data being submitted, so I believe some data are overrided... I used the sleep() so, am I using multi-threads correctly here? But What should I change?
For example, when I submit set1, set2, set3. On my website, I'm receiving set3, set2, set3.
Code:
try
FileInputStream fis = new FileInputStream(myInternalFile);
DataInputStream in = new DataInputStream(fis);
BufferedReader br = new BufferedReader(new InputStreamReader(in));
String strLine;
int i=0;
int internal_entries=0;
while ((strLine = br.readLine()) != null )
Data.array_data[i]=strLine;
if(i==19) //submit after collecting 0-19 results
Thread t = new Thread(new Runnable()
@Override
public void run()
postData();
t.start();
i=-1;
i++;
in.close();
catch (IOException e)
e.printStackTrace();
Code:
public void postData()
Send.send_data();
try
Thread.sleep(5000);
for(int i=0; i<=19; i++)
Data.array_data[i]=null;
catch (InterruptedException e)
// TODO Auto-generated catch block
