K
KOLIO
Guest
I received this battery yesterday and was very impressed with the strength of it. However, I have had major issues with data signals and GPS. I had a seen some sporadic posts regarding these issues, but I am definitely having issues. I tried calling the company today only to find that both numbers (toll free and local) have been disconnected.
Help!?!?
What sporadic posts regarding data signal & GPS issues? I've only read one post on GPS issues (from AMAZON) & even then the OP couldn't make a positive determination of the cause.
Got any links to these other posts,please?
This is a physical issue with the battery itself. Since it extends down the back of the phone, it can interfere (block) your antennas. I've seen talk about this too, some people have the issue, others do not. I don't really see any remedy for this as it's purely physical. There are other good extended batteries that will give you lots of juice, though not as much as this one, but not block your signals. If you can't get a hold of them, file something with Amazon, they're always good at helping their customers.
Again,only one post mentioning a data &/or GPS issue.Out of 33 reviews of this battery on AMAZON:
5 Star= 26
4 Star= 3
3 Star= N/A
2 Star= 2
1 Star= 2
I agree 100% that there are other options for decent battery life & don't doubt for a minute one's issues that they're experiencing.I just am inclined to believe that there may be other issues affecting data/GPS issues.Perhaps if you know of someone that has an SGS III & wouldn't mind using the battery for a few days to see if they could replicate the data/GPS issues.If so,I'm sure AMAZON would appreciate having such information for future reference.
I had my doubts about this battery as well,but fortunately,myself & most others have had a positive experience w/it.At least w/AMAZON,you have their backing & should have no problem getting a refund on your purchase if any subsequent attempts to contact the seller prove fruitless.Good luck & keep us posted on the outcome of your situation.
