Help Wpa2-psk
Williamw545
Does anyone know of a way to 'pick' the PSK right off of the device itself,
should be in there somewhere.....right
:confused:
##### Example wpa_supplicant configuration file ###############################
# This file describes configuration file format and lists all available option.
# Please also take a look at simpler configuration examples in 'examples'
# subdirectory.
# Empty lines and lines starting with # are ignored
# NOTE! This file may contain password information and should probably be made
# readable only by root user on multiuser systems.
# Note: All file paths in this configuration file should use full (absolute,
# not relative to working directory) path in order to allow working directory
# to be changed. This can happen if wpa_supplicant is run in the background.
# Whether to allow wpa_supplicant to update (overwrite) configuration
# This option can be used to allow wpa_supplicant to overwrite configuration
# file whenever configuration is changed (e.g., new network block is added with
# wpa_cli or wpa_gui, or a password is changed). This is required for
# wpa_cli/wpa_gui to be able to store the configuration changes permanently.
# Please note that overwriting configuration file will remove the comments from
# it.
update_config=1
# global configuration (shared by all network blocks)
# Parameters for the control interface. If this is specified, wpa_supplicant
# will open a control interface that is available for external programs to
# manage wpa_supplicant. The meaning of this string depends on which control
# interface mechanism is used. For all cases, the existance of this parameter
# in configuration is used to determine whether the control interface is
# enabled.
# For UNIX domain sockets (default on Linux and BSD): This is a directory that
# will be created for UNIX domain sockets for listening to requests from
# external programs (CLI/GUI, etc.) for status information and configuration.
# The socket file will be named based on the interface name, so multiple
# wpa_supplicant processes can be run at the same time if more than one
# interface is used.
# /var/run/wpa_supplicant is the recommended directory for sockets and by
# default, wpa_cli will use it when trying to connect with wpa_supplicant.
# Access control for the control interface can be configured by setting the
# directory to allow only members of a group to use sockets. This way, it is
# possible to run wpa_supplicant as root (since it needs to change network
# configuration and open raw sockets) and still allow GUI/CLI components to be
# run as non-root users. However, since the control interface can be used to
# change the network configuration, this access needs to be protected in many
# cases. By default, wpa_supplicant is configured to use gid 0 (root). If you
# want to allow non-root users to use the control interface, add a new group
# and change this value to match with that group. Add users that should have
# control interface access to this group. If this variable is commented out or
# not included in the configuration file, group will not be changed from the
# value it got by default when the directory or socket was created.
# When configuring both the directory and group, use following format:
# DIR=/var/run/wpa_supplicant GROUP=wheel
# DIR=/var/run/wpa_supplicant GROUP=0
# (group can be either group name or gid)
# For UDP connections (default on Windows): The value will be ignored. This
# variable is just used to select that the control interface is to be created.
# The value can be set to, e.g., udp (ctrl_interface=udp)
# For Windows Named Pipe: This value can be used to set the security descriptor
# for controlling access to the control interface. Security descriptor can be
# set using Security Descriptor String Format (see MSDN | Microsoft Development, Subscriptions, Resources, and More
# library/default.asp?url=/library/en-us/secauthz/security/
# security_descriptor_string_format.asp). The descriptor string needs to be
# prefixed with SDDL=. For example, ctrl_interface=SDDL=D: would set an empty
# DACL (which will reject all connections). See README-Windows.txt for more
# information about SDDL string format.
#ctrl_interface=DIR=/data/misc/wifi GROUP=system
ctrl_interface=DIR=/data/misc/wifi GROUP=wifi
# IEEE 802.1X/EAPOL version
# wpa_supplicant is implemented based on IEEE Std 802.1X-2004 which defines
# EAPOL version 2. However, there are many APs that do not handle the new
# version number correctly (they seem to drop the frames completely). In order
# to make wpa_supplicant interoperate with these APs, the version number is set
# to 1 by default. This configuration value can be used to set it to the new
# version (2).
eapol_version=1
# AP scanning/selection
# By default, wpa_supplicant requests driver to perform AP scanning and then
# uses the scan results to select a suitable AP. Another alternative is to
# allow the driver to take care of AP scanning and selection and use
# wpa_supplicant just to process EAPOL frames based on IEEE 802.11 association
# information from the driver.
# 1: wpa_supplicant initiates scanning and AP selection
# 0: driver takes care of scanning, AP selection, and IEEE 802.11 association
# parameters (e.g., WPA IE generation); this mode can also be used with
# non-WPA drivers when using IEEE 802.1X mode; do not try to associate with
# APs (i.e., external program needs to control association). This mode must
# also be used when using wired Ethernet drivers.
# 2: like 0, but associate with APs using security policy and SSID (but not
# BSSID); this can be used, e.g., with ndiswrapper and NDIS drivers to
# enable operation with hidden SSIDs and optimized roaming; in this mode,
# the network blocks in the configuration file are tried one by one until
# the driver reports successful association; each network block should have
# explicit security policy (i.e., only one option in the lists) for
# key_mgmt, pairwise, group, proto variables
ap_scan=1
# EAP fast re-authentication
# By default, fast re-authentication is enabled for all EAP methods that
# support it. This variable can be used to disable fast re-authentication.
# Normally, there is no need to disable this.
fast_reauth=1
# OpenSSL Engine support
# These options can be used to load OpenSSL engines.
# The two engines that are supported currently are shown below:
# They are both from the opensc project (OpenSC Project)
# By default no engines are loaded.
# make the opensc engine available
#opensc_engine_path=/usr/lib/opensc/engine_opensc.so
# make the pkcs11 engine available
#pkcs11_engine_path=/usr/lib/opensc/engine_pkcs11.so
# configure the path to the pkcs11 module required by the pkcs11 engine
#pkcs11_module_path=/usr/lib/pkcs11/opensc-pkcs11.so
# Dynamic EAP methods
# If EAP methods were built dynamically as shared object files, they need to be
# loaded here before being used in the network blocks. By default, EAP methods
# are included statically in the build, so these lines are not needed
#load_dynamic_eap=/usr/lib/wpa_supplicant/eap_tls.so
#load_dynamic_eap=/usr/lib/wpa_supplicant/eap_md5.so
# Driver interface parameters
# This field can be used to configure arbitrary driver interace parameters. The
# format is specific to the selected driver interface. This field is not used
# in most cases.
#driver_param="field=value"
# Country code
# The ISO/IEC alpha2 country code for the country in which this device is
# currently operating.
#country=US
# Maximum lifetime for PMKSA in seconds; default 43200
#dot11RSNAConfigPMKLifetime=43200
# Threshold for reauthentication (percentage of PMK lifetime); default 70
#dot11RSNAConfigPMKReauthThreshold=70
# Timeout for security association negotiation in seconds; default 60
#dot11RSNAConfigSATimeout=60
# Wi-Fi Protected Setup (WPS) parameters
# Universally Unique IDentifier (UUID; see RFC 4122) of the device
# If not configured, UUID will be generated based on the local MAC address.
#uuid=12345678-9abc-def0-1234-56789abcdef0
# Device Name
# User-friendly description of device; up to 32 octets encoded in UTF-8
device_name=Wireless Client
# Manufacturer
# The manufacturer of the device (up to 64 ASCII characters)
manufacturer=Samsung Electronics
# Model Name
# Model of the device (up to 32 ASCII characters)
#model_name=cmodel
# Model Number
# Additional device description (up to 32 ASCII characters)
#model_number=123
# Serial Number
# Serial number of the device (up to 32 characters)
#serial_number=12345
# Primary Device Type
# Used format: <categ>-<OUI>-<subcateg>
# categ = Category as an integer value
# OUI = OUI and type octet as a 4-octet hex-encoded value; 0050F204 for
# default WPS OUI
# subcateg = OUI-specific Sub Category as an integer value
# Examples:
# 1-0050F204-1 (Computer / PC)
# 1-0050F204-2 (Computer / Server)
# 5-0050F204-1 (Storage / NAS)
# 6-0050F204-1 (Network Infrastructure / AP)
device_type=1-0050F204-1
# OS Version
# 4-octet operating system version number (hex string)
#os_version=01020300
# Credential processing
# 0 = process received credentials internall
thats just an example page, not what they are using.
the pass key being used is blank, but you cant use a blank password.
I have turned off encryption for the built in hotspot so that it lets me connect to it.
But then you face the problem that the phone isnt setup to be DHCP for issuing IP address's.
After getting that going and being able to connect and be issued an IP. the phone is still not routing traffic out over 4G
so its not just as simple as getting the password.
The pass key being used is blank, but you cant use a blank password.
But then you face the problem that the phone isnt setup to be dhcp for issuing ip address's.
After getting that going and being able to connect and be issued an ip. The phone is still not routing traffic out over 4g
aarrrggghh!!!
