Wrong location.
What happens if you turn wireless location off, i.e. set location to "device only"?
My guess is that Google's map of cellular towers or wireless routers is wrong/out of date and your location is being messed up by that. If so then you'll get the right location if you go device only, though then some apps which only use wireless location won't be able to locate you.
Upvote 0
What happens if you turn wireless location off, i.e. set location to 'device only'?
I've tried everything but still the same thing. Widgets in app locations coming out wrong
Upvote 0
BEST TECH IN 2023
Smartphones
