So I tried as you suggested, now I've got a new issue; phone will not play ANY ringtone or song at all when I get an e-mail... calls, txts, alarms, calendar all play the right tones, just not my effin e-mail!! I'm about to do a full reset on the phone, but don't really want the hassle of dl'ing all my apps againOne issue I noticed is that Android references ringtones numerically in the order they were "discovered." As a result, mounting / remounting my SD card would change my ringtones. As a result, I keep them in internal memory and that cut down on my problems.
I had weird problems with my ringtone randomly changing as well. I usually saw it happen right after I mounted the phone for USB storage. After disconnecting, my ringtone would be changed to something random or the default ringtone. I was able to remedy this by copying my custom ringtones to the /system/media/audio/ringtones folder or whatever it is. Haven't had a problem since.
Only for stock rt's, not for dl'd or installed, they shld show up...Don't you need root to read/write to that folder?
Ringtones changed on me just now when I restarted the phone.
