Hi everyone, I just bought X10 mini. Autofocus does not work
. Only pics in range less than 10-20cm are in focus. It looks the focus is locked in macro mode. Trying to point&focus somewhere else is impossible. I also tried a factory reset but no way. Shall I simply return it to the shop or do you think this could be a software issue?
Thx for your help. John.
Model: E10i
Firmware: 2.1 update1
Kernel 2.6.29
Build 2.1.1.A0.6
. Only pics in range less than 10-20cm are in focus. It looks the focus is locked in macro mode. Trying to point&focus somewhere else is impossible. I also tried a factory reset but no way. Shall I simply return it to the shop or do you think this could be a software issue?Thx for your help. John.
Model: E10i
Kernel 2.6.29
Build 2.1.1.A0.6
