Do you have a Launcher installed and running?
Instead of going to Settings, do you have an option for Preferences?
What Launcher is installed?
If you don't have one installed, you might want to try one out to see if that fixes it. Install Launcher Pro or some other launcher....maybe ADW Launcher....I like Launcher Pro...but that has the option to turn orientation on and off....hopefully it's not a hardware issue.
