I was being stupid i wanted to install [Cyanogen6.1.3]gingerbread[v01] so i changed my baseband and in the settings it said unknown baseband i thought it said that because i my firmware wasn't updated to [Cyanogen6.1.3]gingerbread[v01] so i went on with the normal installation everything went fine it booted up i got to the lock screen and everything was fine but it freeze's after a bit and reboots then everything all over again
Also i got as far as going to my settings but it still said baseband unknown
and if it helps i was using Eminence_v1.2 if that helps
Please help i know i was being stupid but i would appreciate any help i can get
Thanks
EDIT
I believe i fixed it just reinstalled the baseband
Thanks
EDIT
