Help x10 upgrade trouble
Have upgraded my x10 and the pc says upgrade complete but phone still shows 1.6 not 2.1. Followed steps exactly but no luck. Did i miss something i had to do to the phone?
If you tried to use PC Companion to update, I still don't trust it.
Download and install SEUS from Sony and then try and update with it.
Or if you want to check the list -
Xperia X10 | Product Launch Blog
You can search for your phone's number in the list. If it is in the list, then it should have received the update...or is ready for the update.
