Help x10a fw out!!
hey thanks for the update . i have x10a unbranded it worked for me and i got the R2BA020 and before it was R2BA014 . thanks again :)
really i have a x10a unbranded as well but it doesnt let me update, it says i have the lastest firmware. how did you do it?
maybe try uninstalling the seus and download it again from canada region see if it works :) . when u unbrand your phone did u use north american firmware?
if you have a branded x10a with rogers you can update the fw to 20 now using seus. but us x10a unbranded still no luck :(
So, the first post in this string says it is for Rogers branded X10a using SEUS. The next person to download says it is for unbranded (using North American firmware).
So... which is it? OR is it both?
Is there an update for Rogers branded X10a??
Thanks:confused:
Next question for anyone who has updated a branded Rogers X10a...
I have unlocked my phone and currently using it on Telus. It works great.
Does anyone know if I update the software to the new firmware will it affect the unlock status?
Thanks in advance...;)
battery life improvement also and major improvement on timescape u can now change the theme . calls are loud so as the speakers than before. boots up faster , lockscreeen is smoother
Im on Rogers, living in Ontario. Got nothing, still says i have latest update both on PC and Phone. Btw what is Seus, tried to look for on google, came up empty handed.
EDIT: Woot i got it, and sorry for the stupid question. For those wondering SEUS is the regular Sony Ericksson Update Service, idk why i wouldnt think that in the first place. It does in fact say i have an update, can confirm.
So does this have to be done through a pc then? It cannot be accessed truth the update feature on the phone itself?
I talked to Rogers and they said you have to do it through the computer. The update service on the phone does not work yet, so the only option is to do it through the computer.
Changes ive noticed:
  • More responsive screen
  • Unlock screen is smoother.
  • Menus are smoother and include sort of a fade effect when opening and closing.
  • Themes are now included in timescape.
  • You may now choose wallpapers from mediascape from main menu.
  • Back up and restore is now included in the phone itself.
Thats everything ive personally noticed right now.
