Help x10i - Bluetooth problems
cepa
Hi
I've only had my phone a couple of weeks and pleased with it now that I have installed many of the recommended free apps.
I have one problem though with the bluetooth. When I connect to my car bluetooth, everything is fine for 8 minnutes - calls can be made and received but then the bluetooth drops. As this happens when I am driving the easiest way to reconnect is by pressing the connect button in my car (ie not on the handset). It re-connects straight away and then works perfectly for the rest of the journey. This happens everytime I am in the car !
I'm fairly sure the problem is with the phone as my Nokia5800 did not have this issue.
Any ideas anyone ?
Thanks
Hi and welcome to Android Forums!!
Gonna move your thread to the x10i section
Edit: not sure if this is the right phone forum, PM me anyone that sees this if i moved this thread to the wrong section (or any guide/mod that is online)
Hi Cepa, I responded to your other post about Bluetooth probs.
Let us know how it works out, cos as you can see you are not alone!
