davegreatorex
Hi i have just got a x10i which works ok
it is unlocked and has the O2 uk firmware on it
i was at first unable to access the internet, so i phoned three they guide me through the process of setting it up......this failed and it still didnt work!
i then found the internet set up tool on the sony site which didnt have the correct one for the three network .
So used the X10 mini settings which worked
i now have internet .....however i can only connect through edge
so i ask :
I hope that someone can help its a kick in the teeth when you buy something this expensive????
so i ask :
- does any one have this phone on three UK
- if so what are your settings
- any idea why i would only get edge i checked the box it is an X10i?
- Is it worth risking genric firmware?
- If so which one is the newest uk one?
- And where is a good simple guide to set up
